i tried:
toggling the Now Playing Screen > Compact Player > Floating player option
importing themes from the forum that clearly have a floating now playing screen
to reinstall the app to reset settings
no effect
floating player just doesn’t seem to work on my device
I’m on a Pixel 4a with LineageOS 22.2-20250619-NIGHTLY-sunfish (based on Android 15) (bought the app via Ko-Fi).
I read through the logs of me toggling the setting, but there seems to be nothing interesting in there.
Let me know if you need any more information.
Upload description: zitrone
Tolriq
July 17, 2025, 12:28pm
2
You do not show how the player looks like so hard to answer.
I installed this theme to test: Spotify Theme + Now Playing style Tidal
According to the screenshots it has a small floating player and no “now playing” button in the navbar.
I wanted to upload a screenshot of the now playing screen, but the upload doesn’t seem to work.
It basically looks like the now playing screenshots from the post above, but with a navigation bar that obfuscates the lower 4 buttons.
Tolriq
July 17, 2025, 1:52pm
4
Hum don’t install the Android TV version ?
omegalul thats it
thanks
i installed symfonium via obtainium from apkpure because i aurora store seems to be broken more often than not
seems like that was a bad idea
