FLAC embedded cue sheets handling issue over SMB
Embedded cue sheets are handled correctly when using a local storage source, but they do not work when accessing FLAC files over SMB. Meanwhile, separately stored cue sheets are handled properly over SMB, which makes this issue specific to embedded cue sheets.
Upload description: b1tm0r-embedded-cue-smb
I’m using a Synology NAS as the SMB server.
It happens in SMB use cases.
Samba
There’s no sync in the logs so can’t tell the issue.
Was able to reproduce fixed in next release.
