I have added my jellyfin to the Symfonium App. How long does it take to sync the music in the app?
It is already two hours that the app is trying to sync my Jellyfin Library.
I can’t see any progress in the app.
It should be fast, it probably did not start for some unknown reason, if you press the top right filter button it should show if it’s syncing or not and allows to start a sync.
In all cases logs would tell what is going on. [Wiki] How to gather logs and open an issue
