When a track is selected to be included in a playlist, a dialog box labeled “Select playlist” appears, with a “+ Create playlist” button at the top. You can now select your preferred playlist to add the track. All good! The issue is when you have a large number of playlists, requiring endless scrolling to find the one you want. The addition of a filter or search option would enhance the UX by making it easier to sort or filter playlists with specific keywords.
While it’s not a major issue, it would certainly be helpful when managing a large number of playlists.
Explained above
