Just started with this app and so far it does everything I wanted with the one exception. There is no heart button on the wear app.
My use case is that I listen to random stuff while driving, if something comes on that I like I will favorite it from watch to build playlists.
I see this was added to Android Auto but I’m my case I just use straight Bluetooth.
Can’t be the only one. I would be ecstatic if this could be added.
So are you referring to Wear OS controlling this not the Symphonium app at all? I have looked high and low and can’t find a setting that would allow me to change this.
Beautiful thanks, I had to lose the back button because none of the ones there showed up on mine. Might be because its 40mm, bottom row is taken up with source and volume which can not be changed by the looks. In any case that’s solved my issue.
