exus
1
The app used about 70GB of mobile data in the last week.
I re synced but i was connected to WiFi. But when i left home… It used up all data.
I don’t have auto cache images selected on the host.
I can’t find any other option in the settings that could have caused that.
How can I make sure that in the future mobile data is not used anymore in the app.
Upload description: Exusa
Google Drive
Tolriq
2
Your logs does not show anything happening and I unfortunately can’t read the past.
Be sure to have the provider configured to wifi only if you do not want mobile data to be used.
exus
3
The provider is set to wifi only.
I use 5G mobile network
I synched my provider and when i left home i guess it continued in mobile data.
But according to data usage not in the background but in the foreground.
So the wifi only option in the provider is the only wait to prevent data usage of the app?
Tolriq
4
There’s also wifi only for the images in the settings and wifi only downloads.
But no with 11.6.0 if you start sync on wifi it will stop relatively fast when switching to mobile.
