External lyrics not showing
As I understand it, .lrc files (in a separate file with same name as track) synced lyrics from Emby should show in Symfonium but they do not. I also have non synced .txt files that don’t appear either. Is this an Emby not sending the lyrics issue or a Symfonium issue. Thanks.
debug.log (43.0 KB)
Seems your server returns the data differently than mine.
Anyway to have an access to it and those media so I can repro and fix quickly? (You can send details via PM)
