Apologies if this feature is already implemented or discussed, I wasn’t able to find anything in the forums.
For context, I’m using the pcloud integration. I am storing a lot of internet radio shows on pcloud, where each folder is it’s own show, and each “episode” is about 2 hours long.
Playback is perfect, but the files themselves (downloaded from the radio provider’s site directly) do not have artwork embedded as ID3 tags.
I would love to be able to add an image into the same folder on pcloud and use that as fall back artwork in the event that the files in that folder don’t have album art embedded. Happy to be flexible on actual image file name (artist.png / album.png/ cover.png?).
Basing this off of previous use of kodi, having local (to the file, not local on my phone) images available to enhance media playback.
Nicer visualisation and artwork for incorrectly tagged or missing tags.
Nicer user interface/experience, especially for custom library types or badly tagged libraries.
Could also work nicely for podcasts or other non-music audio that can be grouped together with the same “album” art instead of empty.
Kofi uses other files in the same host folder (nfo, png/jpg) to enhance embedded tags in certain media libraries. Would love something similar here.
Have only been using symphonium for a week, and I’ll never look back. Thank you so much for your hard work on this fantastic player.
