Expose Replaygain tags as a string / boolean value
Symfonium is becoming more than just a client for me. The recent changes to check missing artwork on albums, allows me to also manage and view my servers library easily. It actually does a much better job than the server in most cases.
I would like to have a way to view the following replaygain info for example from the expanded player or more details page:
  • Replaygain values
  • Is applied yes/no
  • Applied on album or track basis
Currently, this information is only viewable from captured logs.
Having it directly available as string / boolean values makes it easy to view and manage.
User benefits to assist with music management. But, also assist people to understand if replaygain is being applied and on what basis.
I support this request. My ReplayGain isn’t working and this would help a ton in troubleshooting
Not sure how it can’t be working unless the tags are not there, but, opening an issue with logs will get to the bottom of it. :slight_smile:
Just bumping to say I would also like a way to see if a track has ReplayGain applied and active, through some sort of indicator in the player. And say if it is track or album ReplayGain.
I too would like to have the ability to show/display RG values on Now Playing screens. It seems like it’s the only detail not available except in debug logs…
