Export Smart Playlists To Navidrome
I created a bunch of smart playlists before Navidrome added the ability natively. I would like to be able to export my smart playlists from local (Symfonium) to remote. Even if I can get them in JSON format so I have to manually add them to Navidrome, that would be good.
See above. But basically Navidrome has native smart playlists now and for users with multiple devices or that update phone, this improves QoL.
See above again. It utilities the full function set of Navidrome.
This is not yet present in OpenSubsonic and even if it was, there’s a high possibility that things are not compatible due to difference by being multi providers.
