The expanded player displays a lyrics icon on top of the album art image when available; however, when album images use a light color background the lyrics icon is not visible.
When the song is paused a dark background color is applied to the icon which helps in making the icon visible.
I would like to request a way to tell if a track has lyrics in the expanded player without pausing the track. My suggestion would be to have this background color always visible (if lyrics are available) but other options could be acceptable as well (like placing the icon somewhere else).
I don’t need to pause my track to tell if it has lyrics.
Another issue is that sometimes I assume a track has lyrics (since I can’t tell if the icon is there or not) and try to click the bottom left corner of the image to display the lyrics, but instead I end up pausing my track which is annoying.
Easier way to tell if tracks have lyrics (regardless of the album art colors).
What I’ve seen in other applications is that they always display the icon with the contrast background color for better visibility.
Attaching expanded player screenshots (playing and paused state) where it is really hard to tell if the track has lyrics when paused.
