Excessive battery usage
I’ve had Symfonium installed for a while but just recently started using it as my daily driver for music. Since I started listening daily, it has consume quite a bit of battery, being listed as my highest battery usage app in my battery statistics. I have background enabled for the app and did have unrestricted optimization. In an effort to troubleshoot, I disabled its ‘unrestricted’ background usage to test its consumption. I charged my phone overnight and this morning, I made it a point to not open Symfonium (or any other music app) and my battery consumption is going down just as fast as the previous day and Symfonium is still listed as the highest usage app for battery.
I believe I have all default setting however I did disable ‘prefer internal decoder’ as I saw other posts stating (and the UI does as well) it could save battery.
Upload description: exonintrendo
App has been installed, typical usage or no usage at all.
The logs does not show any activity from the app that could use battery.
No foreground services, your phone restart the app 2 times but then nothing happens.
You can try to capture a bug report Capture and read bug reports  |  Android Studio  |  Android Developers and upload it to https://upload.symfonium.app and provide screenshots of the battery usage from Symfonium.
Do you use some external EQ ? Try to disable system EQ in Symfonium EQ in case it’s something external plugin to the media session.
