WebDAV (webdav.mycloud.ch)
Hi. I sent the debug.log via the app and via the support website.
I opened it on my computer as I was curious to see what hangs/fails.
I know WebDAV is in BETA, hopefully this will be able to make it go into PROD
My webdav does not work properly. I see that it connects and browse as I see some folders in the log. However it does stop prematurely and the library is still empty. The log shows Error/WebDav: Error getting server data 404-Not Found.
Thanks for your help. I’m so close to find the perfect app and buy it (my trial expires on 21-Feb.)
PS : Another player I used to use and that I want to move away from had this issue in the past. It used to work and stopped working. They told me in the support “It looks like the format of the response from Mycloud.ch has changed and we’re not coping with it well” and they indeed were able to make a change that made it work again.
Best Regards,
Stéphane Ernst
Upload description: For the webdav WebDAV (webdav.mycloud.ch) Error/WebDav: Error getting server data 404-Not Found issue as per support request.
Difficult, linked to my webdav. I can’t give you my account and not sure if I can create a test account.
WebDAV
