Numnums
1
Whenever I try to Sync my serve’s library, I get the error 524 from cloudflare due to a connection time, is there a workaround for this?
Upload description: numnums
Tolriq
2
As all the other cases do not use Jellyfin 10.11. It’s slow as hell / bugged for music. Else see if you can increase the timeouts on cloudflare.
Numnums
3
Thank you, is there a jellyfin version you recommend in particular?
Tolriq
4
