Enhance Record Label Tags
I’ve noticed the Record Label Tag must match across an album to appear in symfonium. Not that this is incorrect but I’ve come across a number of albums where a single from the album has more Record Labels in association with it than the others. I’d like for symfonium to sort of gather these tags on the album about page similar to the way album tags, genres & languages are handled.
Not so much of a problem but it can be helpful
Tracks that have more Labels / companies attached can be tagged as such without needing to tag the entire album with those same companies to get them to appear in the app.
This change could also help with filtering at the track level. Currently the user would need to add every Record Label from all the tracks to the Record Label tag, filtering by Record Label in this instance could potentially give incorrect results.
It takes the values from the first song, as the date for example.
Labels are possible album split value, so can’t work that way.
Hi, how do you make appear the label tag? I tried with label or publisher and never appears in Symfonium.
Thanks for your help
AFAIK
MP3 & WAV files use the PUBLISHER tag
FLAC & OPUS use the LABEL tag
Beyond that in the settings for Album Page you’ll need to make sure “Record Label” is enabled in the Visible About Rows section. This documentation may be a bit out of date, we are catching up on that so please bear with us. The steps & settings are still as described.
@BrunoT If that doesn’t work Let me know if you are still having trouble.
Thanks for your reply.
In the album configuration page, yes the tag label is selected to be visible.
But unfortunately on the page of each album it doesn’t appear. Could you help me ?
Yes, I will PM / DM you
