Enable offline cache and download of a single CD in albums
enable offline cache and download of a single CD in albums with multiple CDs tag.
current behavior, if I use the hamburger menu near “Disc 1” for example, it would download the whole album with its multiple CDs -
this could lead to high space usage on the phone for albums with 3 CDs in loseless formats.
easy offline download of a single CD in an album
You can easily multi select the songs you want to quickly offline cache them.
But 3 dots offline cache on the disc should only cache the disc so please provide logs reproducing the issue.
i don’t want to select 10 songs manually, just for listening to a single CD - that’s kind of missing the point. also, i can’t find a way to select all songs of a single CD at once.
I’ve uploaded the logs from the app under my username, and double checked Symfonium actually downloaded the entire two CD’s album (i used Export to downloads directory option) - even though I used the 3 dots on the first CD, in order to only download the first CD (out of two)
thanks
Thanks for the logs so yes the disc filter was not applied in that case will be fixed in next release.
