Hello,
I recently moved from Plexamp to Symphonium on my Android phone and i’m facing two issues with the app for which i didn’t find a solution in forum.
Each time i open the app while something is playing i get the Now Playing screen splashing, which is annoying. So i got to interface settings ans saw that the “Expand player automatically” setting was already off so i don’t understand why it’s splashing when opening or returning to the app.
Any solution for this first issue?
In a second time, i tried to customize the navigation bar by adding some items i want like Albums and Now Playing in order to reach the Now Playing screen from navigation Bar.
When Now Playing is showed on Navigation Bar, the screen is not splashing anymore at start, which is perfect for me, but if i leave the app and return, the navigation bar becomes totally blank with no access to any function, including Settings. Thus i cannot control anything and the only way to get it back is to force stop the app from Android settings and restart. The issues happens everytime the app goes to background and back.
I tried to restore default settings, nav bar works normally again, and i can confirm that this is the fact of adding Now Playing to Navigation Bar that creates this issue of disappearing nav bar.
Any ideas?
Thanks
Upload description: josntrm
Pixel 9 Pro
Android 16 Graphene OS
Add “Now Playing” to Navigation Bar in Interface/Navigation and media start/Main navigation entries settings.
Any provider
