Duplicate of Built-in theme
I somehow managed to generate a duplicate of the built-in “Symfonium” color theme. Since this is not an imported theme, it cannot be deleted and I am thus stuck with two.
It’s just a small nuisance but I wanted to share my data on this in case others encounter it.
Upload description: Cel_ThemeDup
Additional upload: Cel_ThemeDup.symfbkpz
Pass: “cel”
Wasn’t sure what to capture for the bug report, so lmk if there is more I can add. More importantly, I am attaching an app backup containing just my “settings” config. Restoring this backup will restore the duplicate color themes. Restoring any backup which does not contain this bug will return to the (presumably normal) theme assortment saved in the backup.
Sadly, I do not have a backup of my settings without this bug included and the only way I can clear this is via a fresh install.
Unfortunately, I’ve not yet figured out how to reproduce this bug. Will update after more testing. (Sorry!)
That said, I am fairly certain it occured as I was messing about with saving/loading app profiles. Loading the profile wasn’t changing my color theme or something, so I was repeatedly swapping/deleting profiles and themes.
Edited with details of additional upload
That’s crazy, I was literally just coming to report on this again :rofl:
Did you find the issue? Because I finally figured out what causes it. I thought it was something complicated but the steps are actually really simple:
  1. Set the current color theme to “Symfonium”
  2. Save a new Application Style
  3. Change to an AS that uses a different color theme (I used the default “Modern” theme)
  4. Change back to the AS from Step 2
After Step 4, you will now have two “Symfonium” color themes.
Fresh debug log of these steps uploaded as Celorien_DoubleTrouble
Not at all I was cleaning old stuff :slight_smile:
Will look into it with the repro.
