(navidrome, not subsonic)
Hi, I configured “Equalizer/DSP/Volume boost” option to equalize volume between Symponium and Google Maps. Symfonium starts playing when I connect the bluetooth speaker (car), and most times it works correctly, but sometimes the music is too quiet. The workaround I found to fix the volume in such case is to go to the DSP settings and change the volume boost to approximately the same value as it is already. But after such noop change the boost is correctly applied again.
Upload description: darthgandalf
The following is not proved, but it seems that it correlates with when I start navigation in Maps at the same time. However, if that’s relevant, the “short audio focus action” is set to “none”.
P.S. when I’m “fixing” the volume that way, I inevitably change it slightly, just because the slider is so small, and my finger is big, but small changes in boost cause big difference in volume perceived. Please make the slider accept numeric values or e.g. buttons +1/-1
