Downloaded song appearing as 20+ minutes
So when I am listening to downloaded songs and I look at the player, it tells me that the songs are 20+ minutes. I had some appearing as long as 55 minutes. When I look at the same song on wifi tho there is no problem with the length of them. I know I transcode my songs when downloading so I don’t know if the issue could be from there the songs skip just fine even if the displayed length is wrong. I can also skip over the point where the songs auto skip and it just seems to be the same song back to back. If you need anymore info ask. Thank you.
Upload description: Freezy64
Plex
Please search before posting. It’s workaround in the beta already.
Oh, I’m sorry. I tried to do some research but couldn’t find anything. So does that mean that it will be fixed or do I need to do something? If I need to fix it its no problem, I just have no idea where to find the solution. Thank you for the response.
Just told you it’s “fixed” (Actually a Plex bug producing invalid files) in the beta and so the next release when out.
