Does Jellyfin support auto-sync with Symfonium?
I have been constantly adding stuff to my music library and expect that to be the same for the next few weeks. I noticed that Symfonium doesn’t automatically get the new songs and I have to manually tap sync to get them. Is this normal?
It’s possible to sync at every connection. I’m not sure if this the best method…. but I set the server as local one, connected directly to the server ip address when I’m at home, and another “server” with the dynamic dns, when I’m outside home. So at the connection it does the synchronization.
PS: anyway it does not matter which server you use, but in the server setting you can configure the auto sync at the connection.
I don’t see any auto sync button for jellyfin though.
In Manage media provider, the option is there.
I do have that option enabled. But I still have to manually sync every time the library updates.
