Discord Rich Presecence for Music
The ability to link the application to a Discord Application (Using its application ID) to have the music you are listening to show up as your “Playing now” on Discord.
Problem solved / Brought benefits:
Allows users to share with their friends what music they are listening to if they are using their own self-hosted music rather than a mainstream platform.
Feishin has an implementation where the user inputs a Discord Application ID (You can create an application on Discord Developer’s page then copy the ID into the application) and then it will show up on Discord as the attached screenshot. The interface on Feishin is also attached. (feishin/src/main/features/core/discord-rpc/index.ts at development · jeffvli/feishin · GitHub this is the relevant part of Feishin’s codebase).
I have also attached a screenshot from the relevant page in Discord Developers panel, where you can get the Application ID (It is on the first page of the application once it is created)
 Screenshot 1
Use one of the well known solutions like GitHub - dead8309/Kizzy: A Discord Rich Presence manager for Android fully written in Kotlin. Made with jetpack compose and material3
@Tolriq I am aware other solutions exist, however they are 3rd party and bring inconvinence. Having it 1st party in the application itself would make it much more usable than having to tinker with another application.
Why having all music player implement something half baked, when a dedicated specialized app will always do better and support all the apps…
For convenience. Thank you for your time and good work on the app, and it is a shame it won’t be implemented.
I cant get Kizzy to work. Does it require my discord token or logging in? I haven’t tried that yet since it kind of feels like a security concern
Kizzy is a botched piece of trash, in no universe would I consider it a good solution
