Disable the volume popup
I’d like to be able to disable the volume popup when I press the phone’s buttons
I unintentionally pressed the middle of the screen while I was changing the volume, and it rose sharply and hurt my ears
I think it could happen to me again and I’d like to prevent this kind of thing.
This would avoid errors of inattention and pressing on the screen.
I would like to be able to change the volume using only the phone’s buttons.
The dialog is not supposed to be that large and the slider capture clicks everywhere.
This is fixed in next release. You can also miss click on the stop button or the volume bar or start another song or many other miss click. I can’t add settings to prevent everything sorry.
Yeah it’s true, but in this case it can damage ears or speakers. Changing tracks or stopping the music is not so serious
But I understand, thanks for you reply
