Default Repeat All
Hi Tolriq,
I would like Repeat All to be the default playback behaviour.
Thank you.
Every time I start a new playlist, I have to manually activate the Repeat All option. Annoying.
If I forget to activate it, music stops at the end of the playlist. Even more annoying.
Peace of mind ^^
Enable the option retain player state ? Peace of mind :slight_smile:
I know it’s annoying to use the search function and it’s annoying to read the doc too :wink:
I swear the parameter you mention was on! I’ve just discovered that I have a pending playlist with Repeat All set to off…
