Hi,
When I try to use Decade Mix it comes up with the message “not enough songs with years to generate decade mixes” almost all my music has a Year tag (e.g 2007) so what do I need to set to be able to use this feature?
(I checked the FAQ but couldn’t find any mention of it)
Thanks
As the template you deleted says, logs are mandatory
All I can say is that as the message says Symfonium think that you do not have songs with years since you give 0 details.
I thought it would be user error, rather than a bug find attached
---- Technical details, please do not remove ----
Symfonium: 1.4.0B1-615 Android: 11 - 30 [arm64-v8a,armeabi-v7a,armeabi]
Device: samsung - SM-A505FN [a50eea - a50]
debug-20220531_114509.zip (2.0 KB)
Ok so I guess you are using local device songs, Android does not return years for songs.
I should probably derive it from the album data, will see to add that for next release.
Yep that’s right, local device songs… Great thank you
Installed 1.4.0B2, did a rescan and working perfectly, cheers @Tolriq
