I have the app on my tablet and phone. If I download audio to my tablet for local play, it’s not on my phone, I know I can place it in the cloud but it would be great if when loading the apps it checks where they are installed. Looks at the differences, merges it and syncs new music across
Well I used both forms of medium depending where I am, situation and travel.
It means everything syncs perfectly and I can pick up on my phone if I’ve left work or home
As above really.
I could be albums and many tracks missing from one device to another. Leave the home listening to one album and not have it on the next device while travelling. I do alot of direct download onto local drive. If it’s not possible I will just have to keep adding them to Google drive.
It is not possible, there’s no magic in apps to know. You need a server having all the data publishing a playlist for example of what you want synced and have both device auto sync that. The 2 devices can’t talk between them and guess alone.
I’m gonna say: Maybe!
I’m thinking along these lines:
Set both devices to store their downloaded songs in their Downloads folders (pretty sure this is an option in Symfonium), so Syncthing can easily access them.
Set both devices to use their Downloads folders as a Local Device media provider.
Configure Syncthing to synchronise the two folders bidirectionally, i.e. propagate files from A to B and from B to A.
Run Syncthing on both devices to allow the files to synchronise.
In theory, this should make downloaded songs from either device available to both, even if Symfonium doesn’t recognise the synchronised files as its own downloads.
There is a potential for duplicates, though, particularly if Symfonium sees the same tracks through both the server and local media providers, so it’d need some thorough testing first.
You might also want to use something to store the downloaded music in a separate folder within Downloads too, otherwise any file in Downloads would get synced to both devices.
