DAC Input Popup
Beta
Anyway to stop this popup from recurring every time I plug in my DAC
Subsonic (Open)
Plug In DAC
kage125
Playback / advanced / handle USB.
But if you check the always it should be remembered by the OS, without that no exclusive mode.
There is no such option as “handle USB” under Playback/Advanced
Hum then it will be in beta 2 :stuck_out_tongue:
Also there is a popuo regarding Open Symfonium everytime i connect my dongle
So in total two popups
1:- Handle USB
2:- Open Symfonium
Even if i saved the first one to always
I really dont want to open symfonium everytime I plug in the dongle DAC
Okay then
Will be waiting for that
Thanks for the help
That’s a device bug, but in all cases due to how Android works if you want to use exclusive mode there’s no choices.
You can disable exclusive mode in the device output settings.
Couldn’t this be done in a way that Symfonium requests USB Access only when i open the app or if someone requests manually. Via the Playback Output option?
i’m on Beta 2 , having the exact same issue. under Playback → Output devices → Fiio KA5 (my DAC) → i changed USB playback mode to Android default
EDIT: I was actually on Beta 1..my bad. just installed Beta2 and there’s a new option under Playback-> Advanced for “Handle USB audio connections”
but I still get the pop up every time I connect the FiiO . deleting the device from the list doesn’t help, as it returns.
I’m on Android 11, and I also have USB Audio Player Pro installed that I prefer to use with exclusive mode with the FiiO , as Symfonium currently doesn’t pass through properly with the FiiO - I’m using Android Auto that takes control of the phone’s audio, and the only way I can get around it (currently) is using the UAPP app .
but for some reason I have the “set as default” option greyed out when I get the prompt to choose between the two apps at the bottom.
Open your own issue and most importantly about
since that the whole purpose of the version 15 betas.
