Exclude certain track bases on the tags, maybe genre, media type or a custom tag in the personal mix and the radio mix
I have a very random music collection. From classic to indie, pop, music from movies or podcast. The thing is if I want to listen to classical music I have a playlist for it but I don’t want to have it in the personal mix or radio mix, same applies to OSTs.
Improve the quality of the personal mixes and radio mixes. In case any user has a mix of different type of media or has a specific type of music that only wants to listen in a playlist and not get mixed up with the rest of his music when he wants a personal mix.
How is a default list? I mean I can pick any song and start a mix and it will be based on that song.
I have already a random playlist but is useless if suddenly I want a playlist based on a decade or a song. Making every posible option would be impossible
You can use many variables for smart playlists. Making it exactly how you want and dont want it.
What is meant by default list, is that Tolriq has implemented some algorithm or code to these lists that make the upcoming track suggestion I would presume, and, does not want to overhall them.
Then make a dedicated smart playlist, for example using filter “year” set to “greater than” 2010 and “less than” 2021.
For this i would use radio mix and the genre smart queue.
