An ability to customize the lyrics line’s shadow appearance, e.g, a toggle to enable/disable it, shadow X/Y, shadow blur, fill, etc.
Ever since the 13.6.0 beta, all lyrics lines now have a very heavy drop shadow on them by default, almost like a video subtitle. It’s not the case in any previous versions and while it looks fine/very subtle in the lyrics screen itself, it looks quite bad if the lyrics text background isn’t close to the shadow color (black). Be it a dynamic background with the cover/lyrics toggle button, anything.
More customization options and also empowers the user to bring the previous look back as a nice side effect even with the toggle alone.
