Customizable click indicators to disable Ripple Effect
A separate UI configuration option to disable or change the click indicators (or the ripple effect) for the entirety of the UI. Most professional apps don’t have this ripple effect and for me it always puts off the user experience quite a bit since I was never a fan of the ripple effect. Minor issue but ripple makes any app feel less professional? Maybe it’s just me.
Makes the UI seem more professional and less “playful”
Better user experience.
Ripple is the base of Material and aligned with the system. It won’t be removed even behind a setting.
