Currently, when selecting what color to make certain text in the now playing screen, the only options are default and primary color. I’d like a third option for either a custom color, contrasting primary color, or plain old black / white.
If I have the background set to blur, with or without an overlay, the text against certain album colors is very hard to read using either text color option. Same goes with the status bar information.
It will allow the now playing screen be fully customized and easily readable with certain options.
I do want to mention, a lot of the time the adaptive primary color looks great against the background, but on certain albums (especially those with bright colors), it just becomes hard to read. And in my opinion, the black text that shows up on the default option with certain covers doesn’t look good. I think it could also be fixed to show white text and elements any time the overlay is turned on.
Here are my settings:
Background style: Blur
Background overlay: Full
Adaptive primary color: On
All settings with color options: Primary color
Adaptive color is not meant to work on blur background so that’s kinda normal.
The color is extracted from the image and you use the image below there’s no way to calculate efficiently avoid color clash.
With that said currently the full overlay is not taken in account for the calculation.
Could i ask for like, just black/white to be implemented?
I’m using blur bg and blur card overlay for controls n info
it’s sometimes white (perfect cuz card overlay is darker), other times black based on bg (worsens visibility). so like, i just wanna set it to white (others may wanna set it to black based on their designs)
I’m not saying it’s impossible visibility hurdle, but smaller values like duration/year becomes difficult to read
