A way to create and use a custom Now Playing screen for Audiobooks if Symfonium detects that a Audiobook is playing (since we have “media type” now for libraries)
Symfonium uses the same Now Playing screen for Music and Audiobooks, this means that you need to switch themes to get proper Audiobook controls and vice versa.
This would allow 1 theme to fit for both media types.
Other application solutions
Spotify’s solution:
Apple Music Solution:
(Yes, Apple separated Music and Audiobooks into 2 different apps, 3 if you also count Podcasts)
