Custom Home Screen Icon / Banner
Fun Reminder that you can edit the home screen header / icon
I had some fun with this one, it looks a bit better in dark mode due to my shoddy photoshop skills but i still think it looks cool so I had to share it
The Micro SD card has text that changes color because it is an image with holes, it simply shows whatever background / color is on the other side. I got this Idea from a live wallpaper I made a while back that uses the same trick.
If you want to do something similar you’ll need to create a few test images to see where all the borders & elements appear on your display. From there the possibilities are endless!
Lwk sick but I’m so bad at Photoshop
Honestly you can keep it simple. I actually used product images from amazon so deleting the background was a couple clicks, i looked up a tutorial. Then you could just throw a name or nickname up there & call it a day.
I also debated just having a logo or an inage of a vinyl sleeve with a vinyl sort of peaking out. For the more specific items like that you could even download a photoshop mockup & then youd basically just drop any image in & its done
I’m definitely testing this out now with some vinyls on Amazon!
This is so sick lol. Great job.
