Explanation of Current Sound Issue: When I use this software to mix tracks or randomly select a song to play, there is a probability of encountering current sounds. Sometimes it starts normally but later, when it reaches the high-pitched parts, current sounds also appear. Initially, with the equalizer processing engine, bass boost, EQ, and audio virtualizer all enabled, this issue arose. After turning them off, it temporarily disappeared, although it still occasionally happens. If it were just like this, I could tolerate it, but later, when I reopen the software and listen again, the above situations recur, which is really unbearable. Therefore, I still want to provide feedback and hope you can resolve it. Generally, resetting the playlist or toggling the equalizer settings can make it a bit better (but there are still some issues). I haven’t encountered similar situations with other playback software, such as Yinliu and QQ Music.
Environment: The phone is Xiaomi 15, system version: hyperOS 2.0.17.2.VOCCNXM, Android version: Android 15, Security Update: 2024-10-01. Symfonium software version: 11.4.0.
I hope to receive support. Thank you.
Upload description: caiyang2024_11_15
Some settings of the equalizer, such as bass boost and audio virtualizer, may cause current sounds to occur probabilistically when enabled, and other settings could also potentially trigger them. Sometimes, even with all equalizer settings turned off, there is still a probability of encountering current sounds.
