Cue sheets song duration interpreted wrongly
I have two albums which are a FLAC file + cue sheet. The song durations are correct in the cue sheets, Poweramp (android) and Strawberry (Linux) reads and interprets everything correctly.
Symphonium, for some reason, extends the duration of every song. Take one album, “The Kick Inside”, looking at the first two songs in the sheet:
TRACK 01 AUDIO
TITLE “Moving”
PERFORMER “Kate Bush”
INDEX 01 00:00:00
TRACK 02 AUDIO
TITLE “The Saxophone Song”
INDEX 01 03:06:22
Symphonium, however, sets the first song duration as 03:09, thus swallowing the start of the second track.
Rescanning does not solve. Reinstalling without importing configs does not solve.
edit: odly, the time difference varies between albums. in the second one, the difference is one second or less. still noticeable
Upload description: Symphonium requested no description on upload
It did and you entered your name :wink:
Ho and thanks for the bad rating BTW, but glad you found this.
Can you upload the full cue files to https://upload.symfonium.app and tell me when done.
So chatGPT converted the image to the cue file and was able to reproduce.
Will be fixed in next release.
Yep sorry, I’m a developer as well so first thing I should’ve done was coming to support. I was frustrated yesterday trying to fix the cue files until I found it was actually a bug in the application.
Anyways, Symphonium was the best player I found so I’m glad youre responding so quickly. I’ll fix the rating and buy the app, it’s perfect.
edit: ah it’s symfonium
