I have a certain folder path for songs in different languages if I want to create a for example a romance best songs from 2 languages that is in separate folder I have to go to the folder location now and select the songs and add it to the playlist but by this if I add new song to that folder I have to manually do this process again
I like to request a feature where when creating a playlist you can choose the folder path(one or more) and the playlist will be synced to those folders currently I am using another music player for this I hope I get this feature in this
More control over playlist like more flexibility
Playlist are more versatile and can be handled with our folder structure like decoupling the playlist from the app to folders
I am still searching for a better solution but I am using musicolet now it’s feels much easier to achieve my playlist through that app
This feature I want is simple when creating a playlist I have a option to choose folder path ( multiple if needed) after choosing the path it create a playlist with songs in those paths and it’s subfolders
Yes I saw that but couldn’t access the sub folders when clicking on add only seeing the main folders cant access the sub folders that was the issue I will try to add the subfolders in the media provider too and see if that’s working or not
Also any way to edit meta tags like some of the flac songs doesn’t have the proper album names
