When I play my ALAC songs, Symfonium generates high-pitched crackling sounds.
This is perfectly audible in my Sennheiser Momentum 4 headphones, which are quite top-notch when it comes to sound precision !
What makes this a bug ? If I play the exact same file in substreamer, the sound is perfectly clear.
That happens with the system equalizer (set to “Music” or “Automatic”) on the Oppo A72.
BUT if I disable all equalizers, same issue.
I can’t really use the built-in Symfonium equalizer, because when I enable it, the sound becomes stuttering like with a bad bluetooth connection. And anyway the crackling persists.
For the time being, I’m reluctantly back to using substreamer.
Here is a song that replicates the issue everytime I play it. Especially after the crescendo, crackling starting at about 2:00 min and getting worse for the next 30 seconds. https://ds.kandalakcha.com:5001/sharing/crE5ElIYP
Well I know quite a few people who would disagree with this
I’m pretty sure that substreamer does not support alac and that it would be transcoded.
You can enable transcoding and see what happens.
Requires a complete restart of the app after kill to be sure the OS does not do stuff specially on Oppo.
Be sure to read https://dontkillmyapp.com/ to disable all Oppo optimizers too for the app.
You can change the Advanced settings equalizer block size to a lower value to reduce cpu usage if your device libraries are not performant enough.
Again to be sure on those device, after changing the setting force kill the app.
THAT unblocked the rest.
Now I can use the built-in EQ and was able to suppress the cracks.
Thank you very much !
I had no idea the block size had an effect on CPU usage (nor on what else to be honest).
Maybe can you add a small text to that regard with the setting itself ?
