When playing files that use Opus directly, or files that have been transcoded to Opus either on the fly or in the cache quite noticeable crackling noise appears when Symfonium is backgrounded and certain other apps are running in the foreground, for example Pokemon Go (note all sounds have been disabled in Pokemon Go, but I assume it’s still sending audio to the system with 0% volume triggering the issue).
The issue usually does not occur when listening to FLAC files, but if I enable offline cache on a FLAC file so it transcodes the issue then appears for that file. On occasion while mucking with caching I’ve had FLAC have the same issue, but I suspect it’s actually still cached in those instances and the UI just isn’t showing the correct information
Upload description: nvxnvx
It sometimes seems intermittent, frustratingly while attempting to reproduce it with logging enabled I had the issue occur playing a FLAC file (Song of Storms), but the issue didn’t occur when playing “7 Minutes” after adding it to the persistent offline cache which made it transcode to Opus, so perhaps the codec is a red herring
Also the app happily let me upload the logs with “nvx” as the identifier, but then the support page said 5 character minimum for the identifier, so I had to upload it a second time as “nvxnvx”
