After I have synced with my media provider (LMS), Symfonium shows the “Last played” times in UTC. This isn’t very user friendly and should be converted to the local timezone of the device.
More user friendly handling of timezones.
The problem is that Symfonium does use local time initially. But then after syncing it gets updated to be UTC. So it’s inconsistent at the moment and you don’t know what timezone is being used.
