Correctly show translated lyrics when there are two lines of lyrics with the same timestamp, not just the latter line。
Hi, Symfonium’s highly customizable UI is simply fantastic! I’m a Chinese user and I found some glitches when I was looking at the lyrics. When listening to songs in foreign languages we often need translations to understand the lyrics more accurately, so Chinese users often use the following format when editing the lyrics metadata:
[00:10.358]There’s a feeling, there’s a fire
[00:10.358]烈火伴随着情绪
[00:12.918]There’s a whisper preaching to the choir
[00:12.918]回响在唱诗班低声讲道声中
So music players often highlight two lines of lyrics, as in the picture below, but in Symfonium it only highlights the latter line, as in the picture below, I’ve looked through the settings but can’t find the option, maybe I’ve overlooked something?
Enabling better understanding by non-native speakers of the song
烈火伴随着情绪
回响在唱诗班低声讲道声中
If you save them like this, at least Symfonium, MusicBee and lms will parse them as multi-line and display them correctly instead of directly skipping to the 2nd line of each pair with identical timestamps.
You could write a script to run this regex on your .lrc files if you wish to automate this step.
Regex:
