The alternate upnp flags are not the same in those last logs.
Can you try again from local with the same settings?
Local via Bubble or Symfonium?
Appreciate your help
Logs sent - local to device works, flac
I played a flac file which now works with alternate turned off. It didn’t work yesterday. ![]()
Plex files still don’t play
Plex FLAC too or just mp4?
If only MP4 then I’ll need a round of bubble logs playing mp4
Flac from Plex doesn’t play.
I’m using the same album.
Local to device with alternate flags on works also now.
The flags is only applied after a change of renderer or better an app kill.
Force closed app, chose device and plays with alternate flags on.
Make no sense that it’s not consistent.
I guess I agree let’s ignore that device then ![]()
Yes please ![]()
It’s old, doesn’t support Spotify connect anymore either ![]()
But it sounds good for what it does with CD and the addition of a WiiM Pro Plus and Symfonium gives it a new purpose.
Great app by the way. I’ve paid for it now. I have mentioned this to a good number of people on the Roon forum who are getting tired of Roon’s lack of fixing issues.
Thank you for your support with this. ![]()
