Connection with Samba SMB doesn't work
I’m trying to share a folder with SMB from my Windows computer. Everything is configured correctly on the computer side, I know because my shared folder is detected by another test application (samba network music player).
However on Symfonium I enter the ip, the file name, I leave sub-folders empty, I enter login and password but when I press add I get an error message under sub-folders:
“Unable to list the contents of this folder, please check the value.”
I’ve tried selecting an existing subfolder in the target folder but nothing works.
Upload description: AllanF / Connection with Samba SMB doesn’t work
Windows 11, samsung galaxy s20+
Set up SMB share on windows (no problem), open symfonium manage media providers, add media provider, Samba (SMB v2/ v3),
Enter ip, name of folder to share, empty subfolders, enter login and password. Error message under subfolders: “Unable to list the contents of this folder, please check the value.”
Samba
Your logs are empty and does not reproduce the issue.
You need to enable logs, reproduce the issue, then upload logs.
