Connecting to Jellyfin on 2 Different Computers, Same network
I have Jellyfin server on two macs on the same network. I can connect to one but not the other. Each has a separate IP but the same username and password. Both have access granted in Jellyfin. I have tried logging out of the connected computer but still can’t connect the other. What am I doing wrong? Thanks.
Logs attached.
debug-20231208_153939.zip (1.5 MB)
Have you tried reaching the “other server” through browser?
Could you please tell me how to do that and what that would accomplish? Thanks.
I tried going to https://192.168.0.131/ but it said this site could not be reached.
Should you can’t reach server through browser, it’d most likely be a non-Symfonium issue.
If it’s local access, it should be 192.168.0.131:8096. How’re you connecting to the first server? The other server should connect likewise.
Through the Symfonium app. The one I can connect to is 192.168.0.179:8096 and the one I can’t is 192.168.0.131:8096. I am using the same login credentials for both.
Did the logs show what the problem may be?
I think most likely it is the problem of jellyfin. Have you changed any settings regarding networking in jellyfin that may have caused this issue? Is it configured correctly with IP & Port?
15:12:29.645 P:Error T:JellyfinLogger
Error during request: 401 / Error processing request.
Your server refuses the authentification, check it’s settings and it’s logs.
I reset the password and everything is working. Thanks for your help.
Where can I find documentation about accessing my Jellyfin server remotely?
Thanks.
Probably on Jellyfin forums.
Be sure to read all the security impacts and be up to date. There was a few security issue in Jellyfin.
