Beta
If a custom string is uses bool conditions, the value doesn’t change when tapping the string.
Live player correctly responds to the bools, only the preview is affected.
All
Set string using bools, example: {F%|bool1=="false"%}{T%|bool1=="true"%}
Set tap or long Press action to Toggle bool1
Tap or long press. Preview value does not change.
Trying to speed run a Halloween theme, so excuse me if the post is sloppy ![]()
Celorien_CompactBool
