The details of the trial should be communicated inside the initial setup (preferably with a button to start it).
Currently, the only way to know that a time limited trail has even started is by looking inside the settings.
Transparency. A user could have started the app, but didn’t do anything (not interacted with the setup), and decide to try it later, but at that point the trial is already shorter or may have already ended.
Users can make full use of the trial time by knowing that it is time limited.
Other application solutions
Other applications solve this by communicating the trial and starting it after the initial setup.
