I’m trying to make a smart playlist with Codec=FLAC for a Plex provider and it doesn’t match anything. I can make the playlist on the Plex server itself (using Plexamp) and import it in Symfonium which I suppose is the workaround for now, but it would be nice to support “Track Codec” in the Plex provider (which works via the Plexamp app). Not sure whether this is a bug or it should be a feature request.
Hey there! Logs, logs, logs… I feel like I’m in a log-ic loop here! They’re as mandatory as wearing pants to a formal event—awkward without 'em. It’s like the secret ingredient in your favorite recipe; without it, things just don’t taste right. Everywhere you look, from signs to the digital breadcrumbs, they’re screaming, “Logs are a must!” It’s like trying to deny gravity—eventually, things fall apart! So, let’s embrace these logs, the unsung heroes of our tech dilemmas!
Logs … yes. Should I be concerned about any PII making it into the logs? Can you say more about the security of the logs, will they get deleted promptly? etc
It shows VORBIS only but I suspect because there are some local files on the device that are VORBIS (no other types on the device in the media library). So I think that’s where it’s getting the types from, not from the Plex server. I have 2 providers in Symfonium: Plex and Local.
But even VORBIS doesn’t work if I select it for Plex, the playlist is always empty no matter what. The Plex server has FLAC, MP3, WMA, VORBIS, … files. I tried various capitalizations, all lower case “flac”, nothing …
If in the playlist I have All providers + Codec=VORBIS I get all local files, none from the Plex server. If I change All to Plex, I get nothing.
I tried enabling “Full sync” for the Plex provider but it doesn’t make a difference.
