Close Lyrics by Swiping Down
When you have the lyrics up, or the cover and lyrics up, it would be great it you could swipe down on the lyrics to close them.
If you removed the button for the lyrics and cover, and have it appear when you swipe up, you can’t remove them unless you go into settings and add the button back. For the full-page lyrics, you can add the exit button, but that can overlap with the song name if you have that up too.
Ease of use for everyone who swipes up for lyrics - just swipe down to get rid of them.
Screenshot of full-screen lyrics with a long title and the close button.
What happens when one is swiping through the lyrics though?
Just use the back gesture or button to close.
The lyrics over cover can’t be enabled via gesture and require a button because the button is needed to revert after.
