Chromecast cast has become inconsistent. It’s hit or miss if it connects. When it does, it randomly disconnects and won’t reconnect.
Othertimes, it works flawlessly until it randomly disconnects
I have the same problem, with both of my chromecasts. I’m a new Symfonium user so I don’t know if it used to work better. Sometimes it just won’t connect no matter how many times I try. I try to disable/enable wifi, reboot phone, reboot chromecast, open google home, etc. Other times it connects immediately. I have no idea why, because there’s nothing I do differently. I don’t have the problem with spotify, youtube, etc. Sometimes it worked before I left the house, then later return and I cannot get it to connect. I also tried enabling the proxy via symfonium, but I still have problems.
I cast mp3 files from my Android phone. Rebooting chromecasts didn’t help. The only error message I sometimes get is ‘current renderer is offline’ and ‘transferring to renderer’ or something like that. I also often see a second instance of the casting device appear in the list of devices when it fails to connect (as if I have three chromecasts, but two with the same name) a bit like on the screenshot (it was connected then). I don’t use a vpn. Any advice?
