Hi there,
new Symfonium user here, switching from DSub.
I do have 2 issues with casting my Music from Navidrome w/ Symfonium to Chromecast, more precisely to Google Nest Hub.
Cover Art disappears on Google Nest Hub
The cover art is there but it starts to flicker after a few seconds and then turns grey. It looks like the picture is doing something “dynamic”, difficult to describe. It may even happen it comes back later and disappears again. This does not happen on Android TV. It also doesn’t happen when using DSub. Sometimes it is only fading a bit but not completely turning grey.
If I’m casting to a group of 2 both pictures can have a different status at the same time (visible/not visible)
Album Artist vs. Song Artist
I do have many Samplers - any chance I can see the song artist while casting instead the Album artist (which is usually “Various Artists”)
Dsub is using Google code from 3 years ago, it’s a miracle that it can still cast. Symfonium use the lastest stuff mostly forced to properly support ambient mode and a few things on Android TV and Google TV. Older stuff was much simpler.
