I think it would be a great feature to be able to choose where the offline cache is stored. Because of android 11, apps don’t have acess to the android/data folder, which is where symfonium currently stores the offline cache, which is already in a readable mp3 format.
The problem I am having, is that I want to be able to use a different mp3 player app, sense im used to it, but I want to use symfonium to sync everything. I could just download everything to the download folder, but that would mean I have two copies of all my mp3s on my phone.
This would allow users to access music for any need, as well as make it easier to orginise everything. Furthermore, I think the more freedom I have with the app, the more comfortable I am using it.
Finamp(GitHub - jmshrv/finamp: A Jellyfin music client for mobile) allows users to choose any location as long as it is a empty folder. Although they claim that it is buggy due to permissions, it works fine for me. I could just use finamp, but I like symfoniums interface much better.
I am running android 13.
The other music app I want to use is musicolet.
The app I was using to access the android/data folder was cx file explorer.
I am using jellyfin as my server (although I doubt that it matters)
Oh sorry I tried to see if it was a duplicate before posting and couldn’t find anything. No problem at all. I am trying to get my whole family to switch to symfonium so I can sync music more easily, but some people just don’t like change. Thanks for your time!
I solved this problem by realizing that running a music server just to sync mp3s to my phone was the wrong path to be going down. I bought a phone with 256G of storage, used Syncthing to sync the files to the phone, and set up a local-files music source in Symfonium. About 10X less trouble than faffing around with Jellyfin/Airsonic/Plex/Whateverthefuck.
I would have done this, but the main thing I want to do with jellyfin is sync playlists, which you cant easily do with syncthing. Sure you can sync m3u files, but still have to manually import them into an app.
I come late to this party but I add my voice to this request.
True, this is a music player, but being able to check what happens under the hood remains, at least theoretically, one of Android’s strengths. The current approach, sadly, reminds me of how iOS considers its users.
I won’t be listing the use cases, I have several in mind, because the point, for me, is freedom. Which is the reason, I believe, why one would go through the pains of self hosting.
Thanks for listening. Still testing the app and this feature would help my decision.
And I have already listed the reasons in a couple of posts
Offline cache is internal for performance reasons. If you just want to download you can export to the download folder and use the file as wanted but it can’t be used as offline cache.
